ARQUIVO CORROMPIDO NO REVIT
3 REPLIES 3
ISABELJACOMO102A
2495 Views, 3 Replies
Bom dia,
Como faço para restaurar um arquivo corrompido no revit??
Já tentei a opção auditar e não deu certo, a menssagem que recebo é que tenho que contactar o suporte da Autodesk, para restaurá-lo manualmente.
Como faço isso??
att.
3 REPLIES 3
in reply to: ISABELJACOMO102A
Try using the most recent backup file. The backup files have a 3 digit number appended to the name like 001, 002 etc. Hopefully you will not have to recreate to much more of your project to get it back where it was.
Thank you for your post. In this case I would first suggest trying to recover the said file from a backup file to then compare overall results.  Sometimes the corrupted file can be salvaged from a recent backup to enable further work on the said project for the end user.   For reference I have included the direct link below with steps to recover from a backup.
File Recovery Backup: http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Please keep me posted.  Thank you and I look forward to your reply.
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
Obrigado pela resposta Michael, mas já tentei utilizar o Backup e não deu certo!!
att.
