Areas,Tags,Rooms and their Associated Levels
3 REPLIES 3
chuttonx
202 Views, 3 Replies
Hi All,
Got myself a little issue that i can't seem to resolve,
Basically it involves Room Tags ( See Image Attached ) and the ability (or lack thereof ) to select Tags on Upper Floors...see attached image for explanation.
3 REPLIES 3
sbrown
in reply to: chuttonx
Was the second floor plan view made as a detail callout by accident? or check the view range. try turning off everything but walls and rooms.
chuttonx
No the Floor Plan is a Floor Plan...The Room TAG is visible, but the diagonals which allow you access to the ROOM rather than the ROOM TAG are just not visible.
Right onto your second question, when the FLOOR is turned off the diagonals are now visible and editable.
Ah hah, This solves the problem but does not seem right, yes it's a workaround although not ideal. Whats your thoughts on this one? Having to turn off floors every time you want to change an upper floor room ? Hmmm...
Hi, Have you looked at the properties of the room bounding lines. These can be set to a height in the same way walls etc can. Maybe they are set to below floor level...?
