See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** Autodesk.Revit.Exceptions.InvalidOperationException: The parameter is read-only. at Autodesk.Revit.DB.Parameter.Set(Double value) at Adsk.DrxDataManagers.DrxAlgorithmRoomCompute.setProjectBasePointElevation(Boolean A_0) at Adsk.DrxDataManagers.DrxAlgorithmAreaCalculation.run() at Adsk.DrxUi.DrxUiProgressTaskDialog.runAlgorithm() at Adsk.DrxUi.DrxUiProgressTaskDialog.DrxUiProgressTaskDialog_Shown(Object sender, EventArgs e) at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme) at System.Windows.Forms.Control.InvokeMarshaledCallbacks() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- UIFrameworkInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkInterop.DLL ---------------------------------------- UIFramework Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFramework.DLL ---------------------------------------- AdWindows Assembly Version: 5.2.8.100 Win32 Version: 5.2.8.100 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AdWindows.DLL ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- UIFrameworkServices Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkServices.DLL ---------------------------------------- UIFrameworkRes Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkRes.DLL ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 5.2.16.300 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AdApplicationFrame.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- PresentationFramework-SystemCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- AddInManagerUI Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInManagerUI.DLL ---------------------------------------- Microsoft.Expression.Interactions Assembly Version: 4.0.0.0 Win32 Version: 2.0.20520.0 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/Microsoft.Expression.Interactions.DLL ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- ManagedMC3 Assembly Version: 8.2.0.0 Win32 Version: 8.2.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/ManagedMC3.DLL ---------------------------------------- APIInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/APIInterop.DLL ---------------------------------------- RevitAddInUtility Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAddInUtility.DLL ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- PackageContentsParser Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/PackageContentsParser.DLL ---------------------------------------- RevitAPI Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPI.DLL ---------------------------------------- RevitAPIIFC Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIIFC.DLL ---------------------------------------- AddInManager Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInManager.DLL ---------------------------------------- KeynoteDBServer Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/Keynote/KeynoteDBServer.dll ---------------------------------------- StraightSegmentCalculationServers Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/StraightSegmentCalculationServers.dll ---------------------------------------- FittingAndAccessoryCalculationServers Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/FittingAndAccessoryCalculationServers.dll ---------------------------------------- Revit.IFC.Export Assembly Version: 15.1.0.0 Win32 Version: 15.1.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/Revit.IFC.Export.dll ---------------------------------------- Revit.IFC.Import Assembly Version: 15.1.0.0 Win32 Version: 15.1.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/Revit.IFC.Import.dll ---------------------------------------- StraightSegmentCalculationServers.resources Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/en-US/StraightSegmentCalculationServers.resources.DLL ---------------------------------------- FittingAndAccessoryCalculationServers.resources Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/en-US/FittingAndAccessoryCalculationServers.resources.DLL ---------------------------------------- AddInJournaling Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournaling.DLL ---------------------------------------- RevitAPIUI Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIUI.DLL ---------------------------------------- RaaSApplication Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/RaaSForRevit/RaaSApplication.dll ---------------------------------------- RaaSApplication.resources Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0223 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/RaaSForRevit/en-US/RaaSApplication.resources.DLL ---------------------------------------- AutoLoader Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/AutoLoader/AutoLoader.dll ---------------------------------------- FittingAndAccessoryCalculationUIServers Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/FittingAndAccessoryCalculationUIServers.dll ---------------------------------------- KeynoteUIServer Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/Keynote/KeynoteUIServer.dll ---------------------------------------- ObjectNumberingUI Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/ObjectNumbering/ObjectNumberingUI.dll ---------------------------------------- PressureLossReport Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/PressureLossReport.dll ---------------------------------------- SectionPropertiesServerDB Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/SectionProperties/SectionPropertiesServerDB.dll ---------------------------------------- DrxCommon Assembly Version: 4.0.813.0 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommon.dll ---------------------------------------- DrxCommonDb Assembly Version: 1.0.5245.27246 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommonDb.DLL ---------------------------------------- DrxCommonUi Assembly Version: 1.0.5245.27253 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommonUi.DLL ---------------------------------------- AreaCalculation Assembly Version: 4.0.813.0 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/AreaCalculation.dll ---------------------------------------- BatchPrint Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0322 CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202015/BatchPrint.dll ---------------------------------------- BatchPrintUtility Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0322 CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202015/BatchPrintUtility.DLL ---------------------------------------- RevitDBLink Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0322 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20DB%20Link%202015/RevitDBLink.dll ---------------------------------------- mscorlib.resources Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll ---------------------------------------- RevitDBLink.resources Assembly Version: 0.9.0.1 Win32 Version: 2012.0.2010.0728 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20DB%20Link%202015/en-US/RevitDBLink.resources.DLL ---------------------------------------- BIM360GlueRevit2015Addin Assembly Version: 4.33.6482.0 Win32 Version: 4.33.6482.0 CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/BIM360GlueRevit2015Addin.dll ---------------------------------------- BIM360GlueAddinsCommon Assembly Version: 4.33.6482.0 Win32 Version: 4.33.6482.0 CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/BIM360GlueAddinsCommon.DLL ---------------------------------------- log4net Assembly Version: 1.2.11.0 Win32 Version: 1.2.11.0 CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/log4net.DLL ---------------------------------------- SSONETUI Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SSONETUI.DLL ---------------------------------------- SSONET Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SSONET.DLL ---------------------------------------- BIM42.Revit2015 Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/RoomFinishing.bundle/Contents/Sources/BIM42.Revit2015.dll ---------------------------------------- ScheduleSyncPro Assembly Version: 1.0.0.1 Win32 Version: 1.0.0.1 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/BIMC-ScheduleSyncPro.bundle/Contents/2015/ScheduleSyncPro.dll ---------------------------------------- ScheduleSyncPro.resources Assembly Version: 1.0.0.1 Win32 Version: 1.0.0.1 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/BIMC-ScheduleSyncPro.bundle/Contents/2015/en-US/ScheduleSyncPro.resources.DLL ---------------------------------------- BrxCommon Assembly Version: 3.0.306.0 Win32 Version: 3, 0, 306, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommon.dll ---------------------------------------- BrxCommonDb Assembly Version: 1.0.5246.28908 Win32 Version: 3, 0, 306, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommonDb.DLL ---------------------------------------- BrxCommonUi Assembly Version: 1.0.5246.28913 Win32 Version: 3, 0, 306, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommonUi.DLL ---------------------------------------- BuildingBook Assembly Version: 0.0.0.0 Win32 Version: 3, 0, 306, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BuildingBook.dll ---------------------------------------- CMIA.RQSelect Assembly Version: 1.0.3.0 Win32 Version: 1.0.3.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/RevitQuickSelect.bundle/Contents/2015/CMIA.RQSelect.dll ---------------------------------------- CoinsSectionBoxApp2015 Assembly Version: 7.0.5182.19125 Win32 Version: 7.0.5182.19125 CodeBase: file:///C:/Users/fsj/AppData/Roaming/Autodesk/ApplicationPlugins/CoinsSectionBoxApp.bundle/Contents/2015/CoinsSectionBoxApp2015.dll ---------------------------------------- IdeateSoftwareISW Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.22135.0000 CodeBase: file:///C:/Program%20Files/Ideate/Ideate%20Software%202015/IdeateSoftwareISW.dll ---------------------------------------- IFCExportUIOverride Assembly Version: 15.1.0.0 Win32 Version: 15.1.0.0 CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/IFCExportUIOverride.dll ---------------------------------------- nwexportrevit2015_12 Assembly Version: 1.0.5169.37515 Win32 Version: main.110912 CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Navisworks/2015/nwexportrevit2015/nwexportrevit2015_12.dll ---------------------------------------- Common Assembly Version: 5.0.813.0 Win32 Version: 5, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/Common.dll ---------------------------------------- CommonDb Assembly Version: 1.0.5245.32558 Win32 Version: 5, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/CommonDb.DLL ---------------------------------------- CommonUi Assembly Version: 1.0.5245.32566 Win32 Version: 5, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/CommonUi.DLL ---------------------------------------- RoomBookInternational Assembly Version: 5.0.813.0 Win32 Version: 5, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/RoomBookInternational.dll ---------------------------------------- RoomQuantities Assembly Version: 0.0.0.0 Win32 Version: 5, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/RoomQuantities.DLL ---------------------------------------- RevitAPIUIMacrosInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIUIMacrosInterop.DLL ---------------------------------------- SDACommon Assembly Version: 2014.0.0.0 Win32 Version: 2014.0.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SDACommon.DLL ---------------------------------------- RevitAPIMacrosInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIMacrosInterop.DLL ---------------------------------------- PresentationFramework-SystemXmlLinq Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll ---------------------------------------- AddInJournalEngine Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournalEngine.DLL ---------------------------------------- AppMgrWrapper Assembly Version: 4.33.6482.0 Win32 Version: 4,33,6482,0 CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/AppMgrWrapper.DLL ---------------------------------------- Microsoft.GeneratedCode Assembly Version: 1.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- AddInJournalClient Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournalClient.DLL ---------------------------------------- RSEnterpriseClientInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RSEnterpriseClientInterop.DLL ---------------------------------------- RSEnterpriseClient Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RSEnterpriseClient.DLL ---------------------------------------- RS.Enterprise.Common.ClientServer.DataContract Assembly Version: 2015.0.0.0 Win32 Version: 2015.0.2014.0606 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RS.Enterprise.Common.ClientServer.DataContract.DLL ---------------------------------------- MacroHookup Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MacroHookup.DLL ---------------------------------------- BrxCommon.resources Assembly Version: 3.0.306.0 Win32 Version: 3, 0, 306, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/de-DE/BrxCommon.resources.DLL ---------------------------------------- ConceptualEnergyAnalysisInterop Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/ConceptualEnergyAnalysisInterop.DLL ---------------------------------------- MessageLoggerInterop Assembly Version: 1.0.4926.23584 Win32 Version: 1.0.0.1 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MessageLoggerInterop.DLL ---------------------------------------- MessageLogger Assembly Version: 1.0.0.1 Win32 Version: 1.0.0.1 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MessageLogger.DLL ---------------------------------------- log4net Assembly Version: 1.2.10.0 Win32 Version: 1.2.10.0 CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/log4net.DLL ---------------------------------------- DBManagedServices Assembly Version: 2015.0.0.0 Win32 Version: 20140606_1530(x64) CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/DBManagedServices.DLL ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- Quantities Assembly Version: 0.0.0.0 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/Quantities.DLL ---------------------------------------- DrxCommon.resources Assembly Version: 4.0.813.0 Win32 Version: 4, 0, 813, 0 CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/de-DE/DrxCommon.resources.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
See the end of this message for details on invokingjust-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************Autodesk.Revit.Exceptions.InvalidOperationException: The parameter is read-only.at Autodesk.Revit.DB.Parameter.Set(Double value)at Adsk.DrxDataManagers.DrxAlgorithmRoomCompute.setProjectBasePointElevation(Boolean A_0)at Adsk.DrxDataManagers.DrxAlgorithmAreaCalculation.run()at Adsk.DrxUi.DrxUiProgressTaskDialog.runAlgorithm()at Adsk.DrxUi.DrxUiProgressTaskDialog.DrxUiProgressTaskDialog_Shown(Object sender, EventArgs e)at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)at System.Windows.Forms.Control.InvokeMarshaledCallbacks()************** Loaded Assemblies **************mscorlibAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18444 built by: FX451RTMGDRCodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll----------------------------------------UIFrameworkInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkInterop.DLL----------------------------------------UIFrameworkAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFramework.DLL----------------------------------------AdWindowsAssembly Version: 5.2.8.100Win32 Version: 5.2.8.100CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AdWindows.DLL----------------------------------------SystemAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------PresentationFrameworkAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll----------------------------------------WindowsBaseAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------PresentationCoreAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll----------------------------------------System.XamlAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll----------------------------------------System.XmlAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------UIFrameworkServicesAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkServices.DLL----------------------------------------UIFrameworkResAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/UIFrameworkRes.DLL----------------------------------------System.CoreAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------System.DrawingAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------PresentationFramework.AeroAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll----------------------------------------AdApplicationFrameAssembly Version: 0.0.0.0Win32 Version: 5.2.16.300CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AdApplicationFrame.DLL----------------------------------------System.Windows.FormsAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------PresentationFramework-SystemXmlAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll----------------------------------------System.ConfigurationAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------PresentationFramework-SystemCoreAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll----------------------------------------WindowsFormsIntegrationAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll----------------------------------------AddInManagerUIAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInManagerUI.DLL----------------------------------------Microsoft.Expression.InteractionsAssembly Version: 4.0.0.0Win32 Version: 2.0.20520.0CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/Microsoft.Expression.Interactions.DLL----------------------------------------UIAutomationTypesAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll----------------------------------------ManagedMC3Assembly Version: 8.2.0.0Win32 Version: 8.2.0.0CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/ManagedMC3.DLL----------------------------------------APIInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/APIInterop.DLL----------------------------------------RevitAddInUtilityAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAddInUtility.DLL----------------------------------------System.Xml.LinqAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll----------------------------------------PackageContentsParserAssembly Version: 1.0.0.0Win32 Version: 1.0.0.0CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/PackageContentsParser.DLL----------------------------------------RevitAPIAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPI.DLL----------------------------------------RevitAPIIFCAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIIFC.DLL----------------------------------------AddInManagerAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInManager.DLL----------------------------------------KeynoteDBServerAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/Keynote/KeynoteDBServer.dll----------------------------------------StraightSegmentCalculationServersAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/StraightSegmentCalculationServers.dll----------------------------------------FittingAndAccessoryCalculationServersAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/FittingAndAccessoryCalculationServers.dll----------------------------------------Revit.IFC.ExportAssembly Version: 15.1.0.0Win32 Version: 15.1.0.0CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/Revit.IFC.Export.dll----------------------------------------Revit.IFC.ImportAssembly Version: 15.1.0.0Win32 Version: 15.1.0.0CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/Revit.IFC.Import.dll----------------------------------------StraightSegmentCalculationServers.resourcesAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/en-US/StraightSegmentCalculationServers.resources.DLL----------------------------------------FittingAndAccessoryCalculationServers.resourcesAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/en-US/FittingAndAccessoryCalculationServers.resources.DLL----------------------------------------AddInJournalingAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournaling.DLL----------------------------------------RevitAPIUIAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIUI.DLL----------------------------------------RaaSApplicationAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/RaaSForRevit/RaaSApplication.dll----------------------------------------RaaSApplication.resourcesAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0223CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/RaaSForRevit/en-US/RaaSApplication.resources.DLL----------------------------------------AutoLoaderAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/AutoLoader/AutoLoader.dll----------------------------------------FittingAndAccessoryCalculationUIServersAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/FittingAndAccessoryCalculationUIServers.dll----------------------------------------KeynoteUIServerAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/Keynote/KeynoteUIServer.dll----------------------------------------ObjectNumberingUIAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/ObjectNumbering/ObjectNumberingUI.dll----------------------------------------PressureLossReportAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/MEPCalculation/PressureLossReport.dll----------------------------------------SectionPropertiesServerDBAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddIns/SectionProperties/SectionPropertiesServerDB.dll----------------------------------------DrxCommonAssembly Version: 4.0.813.0Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommon.dll----------------------------------------DrxCommonDbAssembly Version: 1.0.5245.27246Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommonDb.DLL----------------------------------------DrxCommonUiAssembly Version: 1.0.5245.27253Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/DrxCommonUi.DLL----------------------------------------AreaCalculationAssembly Version: 4.0.813.0Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/AreaCalculation.dll----------------------------------------BatchPrintAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0322CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202015/BatchPrint.dll----------------------------------------BatchPrintUtilityAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0322CodeBase: file:///C:/Program%20Files/Autodesk/Batch%20Print%20for%20Revit%202015/BatchPrintUtility.DLL----------------------------------------RevitDBLinkAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0322CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20DB%20Link%202015/RevitDBLink.dll----------------------------------------mscorlib.resourcesAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_sv_b77a5c561934e089/mscorlib.resources.dll----------------------------------------RevitDBLink.resourcesAssembly Version: 0.9.0.1Win32 Version: 2012.0.2010.0728CodeBase: file:///C:/Program%20Files/Autodesk/Revit%20DB%20Link%202015/en-US/RevitDBLink.resources.DLL----------------------------------------BIM360GlueRevit2015AddinAssembly Version: 4.33.6482.0Win32 Version: 4.33.6482.0CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/BIM360GlueRevit2015Addin.dll----------------------------------------BIM360GlueAddinsCommonAssembly Version: 4.33.6482.0Win32 Version: 4.33.6482.0CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/BIM360GlueAddinsCommon.DLL----------------------------------------log4netAssembly Version: 1.2.11.0Win32 Version: 1.2.11.0CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/log4net.DLL----------------------------------------SSONETUIAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SSONETUI.DLL----------------------------------------SSONETAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SSONET.DLL----------------------------------------BIM42.Revit2015Assembly Version: 1.0.0.0Win32 Version: 1.0.0.0CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/RoomFinishing.bundle/Contents/Sources/BIM42.Revit2015.dll----------------------------------------ScheduleSyncProAssembly Version: 1.0.0.1Win32 Version: 1.0.0.1CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/BIMC-ScheduleSyncPro.bundle/Contents/2015/ScheduleSyncPro.dll----------------------------------------ScheduleSyncPro.resourcesAssembly Version: 1.0.0.1Win32 Version: 1.0.0.1CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/BIMC-ScheduleSyncPro.bundle/Contents/2015/en-US/ScheduleSyncPro.resources.DLL----------------------------------------BrxCommonAssembly Version: 3.0.306.0Win32 Version: 3, 0, 306, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommon.dll----------------------------------------BrxCommonDbAssembly Version: 1.0.5246.28908Win32 Version: 3, 0, 306, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommonDb.DLL----------------------------------------BrxCommonUiAssembly Version: 1.0.5246.28913Win32 Version: 3, 0, 306, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BrxCommonUi.DLL----------------------------------------BuildingBookAssembly Version: 0.0.0.0Win32 Version: 3, 0, 306, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/BuildingBook.dll----------------------------------------CMIA.RQSelectAssembly Version: 1.0.3.0Win32 Version: 1.0.3.0CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/RevitQuickSelect.bundle/Contents/2015/CMIA.RQSelect.dll----------------------------------------CoinsSectionBoxApp2015Assembly Version: 7.0.5182.19125Win32 Version: 7.0.5182.19125CodeBase: file:///C:/Users/fsj/AppData/Roaming/Autodesk/ApplicationPlugins/CoinsSectionBoxApp.bundle/Contents/2015/CoinsSectionBoxApp2015.dll----------------------------------------IdeateSoftwareISWAssembly Version: 2015.0.0.0Win32 Version: 2015.0.22135.0000CodeBase: file:///C:/Program%20Files/Ideate/Ideate%20Software%202015/IdeateSoftwareISW.dll----------------------------------------IFCExportUIOverrideAssembly Version: 15.1.0.0Win32 Version: 15.1.0.0CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/IFC%202015.bundle/Contents/2015/IFCExportUIOverride.dll----------------------------------------nwexportrevit2015_12Assembly Version: 1.0.5169.37515Win32 Version: main.110912CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Navisworks/2015/nwexportrevit2015/nwexportrevit2015_12.dll----------------------------------------CommonAssembly Version: 5.0.813.0Win32 Version: 5, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/Common.dll----------------------------------------CommonDbAssembly Version: 1.0.5245.32558Win32 Version: 5, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/CommonDb.DLL----------------------------------------CommonUiAssembly Version: 1.0.5245.32566Win32 Version: 5, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/CommonUi.DLL----------------------------------------RoomBookInternationalAssembly Version: 5.0.813.0Win32 Version: 5, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/RoomBookInternational.dll----------------------------------------RoomQuantitiesAssembly Version: 0.0.0.0Win32 Version: 5, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Roombook/Program/RoomQuantities.DLL----------------------------------------RevitAPIUIMacrosInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIUIMacrosInterop.DLL----------------------------------------SDACommonAssembly Version: 2014.0.0.0Win32 Version: 2014.0.0.0CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/SDACommon.DLL----------------------------------------RevitAPIMacrosInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RevitAPIMacrosInterop.DLL----------------------------------------PresentationFramework-SystemXmlLinqAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll----------------------------------------AddInJournalEngineAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournalEngine.DLL----------------------------------------AppMgrWrapperAssembly Version: 4.33.6482.0Win32 Version: 4,33,6482,0CodeBase: file:///C:/Program%20Files/Autodesk/BIM360GlueAddins/Revit2015Addin/AppMgrWrapper.DLL----------------------------------------Microsoft.GeneratedCodeAssembly Version: 1.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------AddInJournalClientAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/AddInJournalClient.DLL----------------------------------------RSEnterpriseClientInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RSEnterpriseClientInterop.DLL----------------------------------------RSEnterpriseClientAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RSEnterpriseClient.DLL----------------------------------------RS.Enterprise.Common.ClientServer.DataContractAssembly Version: 2015.0.0.0Win32 Version: 2015.0.2014.0606CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/RS.Enterprise.Common.ClientServer.DataContract.DLL----------------------------------------MacroHookupAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MacroHookup.DLL----------------------------------------BrxCommon.resourcesAssembly Version: 3.0.306.0Win32 Version: 3, 0, 306, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Buildingbook/Program/de-DE/BrxCommon.resources.DLL----------------------------------------ConceptualEnergyAnalysisInteropAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/ConceptualEnergyAnalysisInterop.DLL----------------------------------------MessageLoggerInteropAssembly Version: 1.0.4926.23584Win32 Version: 1.0.0.1CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MessageLoggerInterop.DLL----------------------------------------MessageLoggerAssembly Version: 1.0.0.1Win32 Version: 1.0.0.1CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/MessageLogger.DLL----------------------------------------log4netAssembly Version: 1.2.10.0Win32 Version: 1.2.10.0CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/log4net.DLL----------------------------------------DBManagedServicesAssembly Version: 2015.0.0.0Win32 Version: 20140606_1530(x64)CodeBase: file:///C:/Program%20Files/Autodesk/Revit%202015/DBManagedServices.DLL----------------------------------------UIAutomationProviderAssembly Version: 4.0.0.0Win32 Version: 4.0.30319.18408 built by: FX451RTMGRELCodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll----------------------------------------QuantitiesAssembly Version: 0.0.0.0Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/Quantities.DLL----------------------------------------DrxCommon.resourcesAssembly Version: 4.0.813.0Win32 Version: 4, 0, 813, 0CodeBase: file:///C:/Program%20Files/Autodesk/Roombook%20Areabook%20Buildingbook%20for%20Revit%202015/Areabook/Program/de-DE/DrxCommon.resources.DLL----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration><system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
