Revit Architecture
Distinguished Contributor
diesellam
Message 1 of 6 (493 Views)
area takeoff
493 Views, 5 Replies
09-19-2012 09:27 AM
See attached file.
How can you do the area takeoff of only the selected faces (red area)?
Right now I have to use the 3rd party software to do something like this.  I'm curious if there's a way to do inside Revit?
Thanks in advance.
diesellam wrote:
You mean to apply the material in the wall's type properties?
Yes. Is it not what you need, to estimate materials in a wall? That's what the material take-off schedule is for.
Alfredo_Medina
Message 2 of 6 (485 Views)
Re: area takeoff
09-19-2012 10:09 AM in reply to: diesellam
Paint those 3 faces with a material. Then, in the project, do a material take-off schedule that applies to elements of the same category as this object. That schedule will give you the area per material.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
diesellam
Message 3 of 6 (482 Views)
Re: area takeoff
09-19-2012 10:13 AM in reply to: diesellam
This is just an example of the exterior wall.  Your suggestion is good.
But I have about 1000 of them all over the project.
This is not a feasible solution if I have to paint the materials for all 1000 of them.
You can't isolate the faces of the wall in Revit, can you?
Alfredo_Medina
Message 4 of 6 (476 Views)
Re: area takeoff
09-19-2012 10:16 AM in reply to: diesellam
Oh, if it is a wall, you don't need to paint anything, but configure the components of the wall in its type properties. The material take-off schedule should report that information.
diesellam
Message 5 of 6 (464 Views)
Re: area takeoff
09-19-2012 02:06 PM in reply to: diesellam
Would you mind to elaborate a little bit more?
Alfredo_Medina
Message 6 of 6 (460 Views)
Re: area takeoff
09-19-2012 02:45 PM in reply to: diesellam
