Arched Top in Curtain Wall
5 REPLIES 5
444 Views, 5 Replies
I'm trying to do a Arched Top in 2 of the top panels in the curtain wall, see attached file to see what I mean. Thanks for your help, Jarod Attachment not added (content type not allowed): "Arched Top in Curtain Wall.rvt"
5 REPLIES 5
Something strange happened to your post, I replied this morning, however now my reply is gone. Anyway all you do is select the curtain PANEL by tabbing on the edge of it, then click edit and draw the shape you want.
I'll keeping working on that idea but the model lines aren't sticking. Can you give me a model that has one done? "sdbrown" wrote in message news:30312211.1095284862615.JavaMail.jive@jiveforum1.autodesk.com... > Something strange happened to your post, I replied this morning, however > now my reply is gone. Anyway all you do is select the curtain PANEL by > tabbing on the edge of it, then click edit and draw the shape you want.
dont draw model lines, you should be drawing Sketch lines in Sketch mode to change the shape. "Jarod" wrote in message news:4148bf33$1_1@newsprd01... > I'll keeping working on that idea but the model lines aren't sticking. Can > you give me a model that has one done? > > "sdbrown" wrote in message > news:30312211.1095284862615.JavaMail.jive@jiveforum1.autodesk.com... > > Something strange happened to your post, I replied this morning, however > > now my reply is gone. Anyway all you do is select the curtain PANEL by > > tabbing on the edge of it, then click edit and draw the shape you want. > >
go to AUGI.com, i posted a file there with an Arch-top curtain wall. (easier to post it over there....) "Scott Davis" wrote in message news:4148e744_2@newsprd01... > dont draw model lines, you should be drawing Sketch lines in Sketch mode to > change the shape. > > "Jarod" wrote in message news:4148bf33$1_1@newsprd01... > > I'll keeping working on that idea but the model lines aren't sticking. Can > > you give me a model that has one done? > > > > "sdbrown" wrote in message > > news:30312211.1095284862615.JavaMail.jive@jiveforum1.autodesk.com... > > > Something strange happened to your post, I replied this morning, however > > > now my reply is gone. Anyway all you do is select the curtain PANEL by > > > tabbing on the edge of it, then click edit and draw the shape you want. > > > > > >
Thanks Scott... "Scott Davis" wrote in message news:4148e7ed$1_1@newsprd01... > go to AUGI.com, i posted a file there with an Arch-top curtain wall. > (easier to post it over there....) > > "Scott Davis" wrote in message > news:4148e744_2@newsprd01... >> dont draw model lines, you should be drawing Sketch lines in Sketch mode > to >> change the shape. >> >> "Jarod" wrote in message news:4148bf33$1_1@newsprd01... >> > I'll keeping working on that idea but the model lines aren't sticking. > Can >> > you give me a model that has one done? >> > >> > "sdbrown" wrote in message >> > news:30312211.1095284862615.JavaMail.jive@jiveforum1.autodesk.com... >> > > Something strange happened to your post, I replied this morning, > however >> > > now my reply is gone. Anyway all you do is select the curtain PANEL > by >> > > tabbing on the edge of it, then click edit and draw the shape you > want. >> > >> > >> >> > >
