Arc walls
2 REPLIES 2
mthemelis
204 Views, 2 Replies
Arc walls
I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters.
How is it possible to create something like that?
2 REPLIES 2
in reply to: mthemelis
Draw the wall in plan. Go to the elevation and draw a slopping ref. plane from one end of the wall to the other. Select the wall. Use Top/Bottom - Attach - Pic the Ref. Plane. You can move and rotate the ref plane later to modify the slope. "mthemelis" wrote in message news:33359346.1092688217055.JavaMail.jive@jiveforum2.autodesk.com... > I want to create an arc wall that starts with 12 meters heght and ends with a height of 8 meters. > How is it possible to create something like that?
mthemelis
Ok thank you!
