Applying Formula to Label or between Project Parameters
2 REPLIES 2
4857 Views, 2 Replies
Hello. I'm a Revit user in S.Korea.
I'm now making a new room tag family (Family Category : "Room Tag" from generic annotations template)
And the problem can be explained with the image below:
There's no problem making a label/parameter "pyung",
but there is a problem applying the formula "Pyung = Area / 3.3"
I couldn't find a way to apply the formula at Family Types Window.
I have also thought for another solution,
: Make shared parameter "Pyung" in Project, and use the parameter as label parameter.
But still, as far as I know, there's no way of applying formula between shared (project) parameters.
Desparately looking for a solution, would be grateful if one give any.
2 REPLIES 2
Alfredo_Medina
It is possible to add calculated values into schedules, but not into tags.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
keshanis
in reply to: Alfredo_Medina
Alfredo_Medina -  Is there a plug in or something that allows it to be enterable in a tag specifically?
