I made the change to the Revit.ini file to make the Temp. Dimensions larger. I saved the file and closed the file, opened Revit and it worked. I wanted to reopen the ini file to change the fonts to 12 points but when I opened it is blank yet the program works. How can I get it back or get a copy of the Revit Architecture 2010 ini file?
You can try a couple of things:
1. Start>Control Panel>Install/Uninstall Programs>choose Revit Architecture 2010> Uninstall>Repair
2. If you have the DVD disc; serach for the .ini file and copy back into the propoer location on your C: Drive
3. Do a complete uninstall/reinstall of Revit
cheers
