I have a slab that has a stair opening cut into it. I thought it was part
of the slab, but when I select the slab and hit edit, it shows the outline
of the whole slab, not the opening. This leads me to believe it is an
opening object that I must modify. I am happy to select this opening
object, delete it, and draw another opening, but I can't seem to select this
object. If indeed it is an opening object. How can I select this object
and delete it? If I isolate the slab it shows the slab with the opening,
but if I select the slab and hit edit. It only shows the outside extents of
the slab, not the opening. Please advise. Thanks.
Regards Peter.
