Elevations, Sections and Callouts are views not annotation. Views are an project based and therefore do not transfer from linked models. Access to the views specific to a Linked file is not available. You can copy Levels and Grids or model and annotation elements/components from Linked Revit files.
To copy Levels and establish those plan or ceiling views in your current project (Hosted) file, you can use the Copy/Monitor command under the Tools menu. Select Link in the Flyout menu and Copy in the Copy/Monitor menu in the Design Bar. Select Multiple from teh Option bar to select multiple Levels to copy and then select Finish on the Option bar to complete the copy of the Linked project Levels into your current (Host) project. When completed the new Levels (Tags) will appear in Black versus Blue. This means they are Levels, but are not plan or ceiling views in the Project Browser. To make these views plan or ceiling views in the Project Browser, select the Newcommand in the Views menu, select the Floor Pan or Ceiling Plan from the New flyout menu and in the Floor Plan views list select the Floor Plans copied from the Linked project file. You will need to repeat this for Ceiling Plans.
You can turn off the Linked project Levels or Grids by opening the Visibility Graphics dialog box and select the Revit Links tab. In the Links list select the appropriate Linked project file and under Display Settings select the By Host View button. In the Revit Link Display Settings dialog box select Custom then the Annotation Categories tab. In the Annotation Categories - Annotation Categories: list select and uncheck the Levels category. You can repeat tthis for Grids as well.
You need to recreate Elevation, Section, Callout and Drafted views from the Linked project file in the Host file.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
