It looks like I hit another snag. I have loaded the family Section Head 1 Point Filled into my Annotations tab in the Project Browser. However, every time I try to "Create Instance", a warning pops up and says, "Can't Create This Kind of Element In This View In the Current Mode". What makes it more strange is that this error only occurs when I try to add section heads/callouts only. I can add the other Annotations work without any issues. Any idea why?
Thanks for posing on the forums
If I understand your issue correctly and walk through your process of adding an annotation
you are using the PB->Families-> Annotation opening the type and R/C on it to Create an Instance.
The reason it gives you this error is that the Annotation FAMILY can only be used when ASSIGNED to a Section Head type. When you Edit the Type of the Section and then change the Section Tag itself you can assign this family.
If you want to use the section Head as a Dummy Symbol then you can Edit the Family and change the Family Category to Generic Annotation.
Otherwise the only way to use the family is mentioned above and invoked using the Section Tool or Callout Tool.
Please let me know if my understanding is incorrect or you are running into further issues
Would it make a difference if the project I am working is connected to a central file? We are using Revit 2015. From here I'm not sure what else to do. See attached. This is all I got so far. Please forgive me for sounding annoying. I am fairly new to 2015.
Update:
If possible, can someone show me a "walkthrough" of it? That would be greatly appreciated.
Thanks in advance!
