Angular Wall Conceptual Massing Problem
1 REPLY 1
Andrew-Adams
463 Views, 1 Reply
Hi all,
I am very new to Revit and am trying to develop my first architectural design. I have created a mass using 3ds Max (had the ability to create the angled walls I wanted) and then exported it as body objects to Revit.
They import great as In-Place masses and there is no problem there. However, when I try to create the structural walls I am getting horrible joins (or not) happening in the cornered areas. I have no idea how to fix them or clean them up, this is a real challenge!! I would greatly appreciate your help!!
I have attached 2 images. First is showing the problem with the walls, and the second shows what the design should look like in the Max model.
Thanks in advance for your help!
1 REPLY 1
If possible can u upload the Mass file then its easier to get the solution.
