Hi all,
I am very new to Revit and am trying to develop my first architectural design. I have created a mass using 3ds Max (had the ability to create the angled walls I wanted) and then exported it as body objects to Revit.
They import great as In-Place masses and there is no problem there. However, when I try to create the structural walls I am getting horrible joins (or not) happening in the cornered areas. I have no idea how to fix them or clean them up, this is a real challenge!! I would greatly appreciate your help!!
I have attached 2 images. First is showing the problem with the walls, and the second shows what the design should look like in the Max model.
Thanks in advance for your help!
Solved by karunakaran1991. Go to Solution.
If possible can u upload the Mass file then its easier to get the solution.
