I am trying to create a soldier course that seems to be working ok however when I test it in a project it arrays at an angle and not at a straight line. I am not sure why Revit is thinking this needs to be arrayed at an angle. i have attached the file with the family in it. Any ideas or suggestions would be great.
Tony
Solved by Alfredo_Medina. Go to Solution.
Some comments:
Thanks for your input.
What would you suggest is the best way to create soldier coursing over windows. Should I create them individually as wall sweeps?
and my next attempt was to create a curved arched soldier course, what would you suggest for that?
Thanks in advance
Tony
It seems to me that the wall sweep is enough for the soldier course above the window. The arch is different, though, because the wall sweep tool works only in horizontal or vertical direction. If you want the arch parametric, that is a rather complex family, but for the linear simple soldier course, the wall sweep is just fine, in my opinion.
That is a great suggestion. I wasnt even aware that you could do that.
Thanks again for all your help.
Tony
