Revit Architecture
Member
info
Message 1 of 7 (1,989 Views)
An error has occurred while drawing the contents of this window
1989 Views, 6 Replies
09-22-2011 08:01 AM
After using the program for a few weeks it appeared the error message "An error has occurred while drawingthe contents of this window" only when I open the 3D view. I reset the Windows user profile and everything is back to normal operation. Today has come out again this error screen. Video drivers are certified and the board is a Nvidea Quadro and normally I have no problems. To test I created a new user and everything works fine.What could alter the software related to user profile? Thk!
Product Support
Chris.Aquino
Message 2 of 7 (1,971 Views)
Re: An error has occurred while drawing the contents of this window
09-22-2011 03:39 PM in reply to: info
If you have not already, I would try disabling (or enabling, if already disabled) Hardware Acceleration in the Revit Options.
I would also try clearing out the Temp folder on the machine. You can do this by hitting Windows+R, entering %temp%, then clearing out as many files as you can.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
Member
info
Message 3 of 7 (1,962 Views)
09-22-2011 11:54 PM in reply to: Chris.Aquino
If I disable the hardware acceleration works but is not the solution, we work with very large projects and we have to use the video card acceleration. I have tried deleting temp files but does not work. thanks
Member
info
Message 4 of 7 (1,933 Views)
09-26-2011 03:16 AM in reply to: info
anyone can help me?
Member
info
Message 5 of 7 (1,931 Views)
09-26-2011 03:36 AM in reply to: info
I have seen that the error occurs simply by clicking a family because it can not display the graphic in the upper left "property" with the type of item eg. wall.
Thk.
New Member
sadhumon916
Message 6 of 7 (1,312 Views)
12-01-2012 12:05 AM in reply to: info
anyone can help me?????????? plzzzzzz....
Member
Rustle
Message 7 of 7 (1,236 Views)
01-09-2013 05:35 PM in reply to: sadhumon916
I am having this problem too.  Only one user has the problem.
