ALL TABS AND RIBBON PANELS MISSING? HELP!!
4 REPLIES 4
766 Views, 4 Replies
I opened revit 2015 and all the panels, tabs and tool bars were missing. I mean.. there is nothing up the top of my revit page? How is this even possible!? Is there ANYONE who can help? I am an Interior Design student and need revit to complete assignemnts.
HELP!
I have attached a screen shot of the page... check it out....
From Mel
4 REPLIES 4
LisaDrago
Hello!
I would assume you closed Revit and re-opened and nothing came back?
I would suggest renaming you Revit.ini file or move it to another folder and force Revit to reset everything.
You can find it in two locations.
Revit uses 2 versions of the Revit.ini file:
  • UserDataCache folder: C:\ProgramData\Autodesk\<product and release>\UserDataCache
  • User Profile folder: C:\Users\<username>\AppData\Roaming\Autodesk\Revit\<product name and release>
Again - I would strongly suggest saving the optional as a back-up.
Give it a try and let us know how it goes.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Hi, Thanks for the suggestion 🙂
I tried that to no avail. I have tried everry conceivable thing and still, whenever I open a new or preexisting file the ribbon simply dissapears and all that is there is a grey space 😞
rosskirby
Close Revit, then delete the UIState.dat file located at C:\Users\YourUsernameHere\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2014
Then reopen Revit.  If that doesn't work, you could try a repair installation (same as a new install, just click Repair).
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Chris.Aquino
If you have not already, I would take a look at the page below:
Revit: User Interface does not display correctly on high resolution monitors
Chris Aquino
Adoption Marketing Manager | BIM Collaborate Pro
@Aquinotecture
