I opened revit 2015 and all the panels, tabs and tool bars were missing. I mean.. there is nothing up the top of my revit page? How is this even possible!? Is there ANYONE who can help? I am an Interior Design student and need revit to complete assignemnts.
HELP!
I have attached a screen shot of the page... check it out....
From Mel
Hello!
I would assume you closed Revit and re-opened and nothing came back?
I would suggest renaming you Revit.ini file or move it to another folder and force Revit to reset everything.
You can find it in two locations.
Revit uses 2 versions of the Revit.ini file:
Again - I would strongly suggest saving the optional as a back-up.
Give it a try and let us know how it goes.
LD
Hi, Thanks for the suggestion 🙂
I tried that to no avail. I have tried everry conceivable thing and still, whenever I open a new or preexisting file the ribbon simply dissapears and all that is there is a grey space 😞
Close Revit, then delete the UIState.dat file located at C:\Users\YourUsernameHere\AppData\Roaming\Autodesk\
Then reopen Revit. If that doesn't work, you could try a repair installation (same as a new install, just click Repair).
If you have not already, I would take a look at the page below:
Revit: User Interface does not display correctly on high resolution monitors
