... I've sliced the original surface in another package. Now each panel is a
surface and I can make sure their aligned. In Revit, as far as I know, it
would be impracticable due to the time required.
Thanks Daniel
"Daniel Legarraga"
wrote in message
news:5520784@discussion.autodesk.com...
Use the "align" command, but one to one...
"R Dias" < escribió en el mensaje
news:5518685@discussion.autodesk.com...
Is there a way to quickly align mullions on a curtain system? The image
attached shows a curtain system made in rhino from 4 distinct surfaces. I
can't make it in rhino as 1 surface but I could do it in 2. I'm sure I will
get a similar problem with 2 surfaces anyway.
I' ve used fixed number between adjacent surfaces but with no success. I've
also tried to align the curtain grid, but I can't manage to stick to snap
points.
For the moment my best idea is to creat
e single panels in rhino and produce
a curtain system with one panel only for each selected surface.
Any suggestions will be higly appreciatted.
R Dias
