Hi there, I am encountering some trouble trying to align a texture to a rectangular rug family that rests upon the floor. I have an image that I'd like to map exactly to the extents of the extrusion, but Revit seems to default to a certain tiling placement that is offset in the corner of the piece, even if I turn tiling off on the texture, and I state the size of the texture exactly to the size of the rug. How do I resolve this? I've attached a PDF to show what is currently happening..
Solved by constantin.stroescu. Go to Solution.
I had this problem too with mapping.
I solved it using two ways:
1
Constantin Stroescu
I can realign my image but when I reload it into my model it does not show the change. Is there something special I have to do to make it show?
