“Aligned to selected levels” is not active,
I’m wondering why the option “aligned to selected levels” is not active as I copy and paste from one level to another.
Thank you
Best
Jamal
Solved by Alfredo_Medina. Go to Solution.
It is because there are annotation elements (dims, tags) included in the selection that was copied to the clipboard.
Thank you for the answer. It works!
But why it is grey out when dim and tags are selected and needed to be pasted?
If the align to level is greyed out, it's because your selection includes something that cannot be copied to another level that is specific to each level, i.e. a dimension, a detail line, a note, etc. This is what I figured out was happening to me.
