Hi All
I am new to Revit.
I am making a family and I am wondering about the best way to attack it.
It is a lighting fixture that has various combinations for the back housing and front attachments.
The Back housing has 6 options
The Front attachment has 11 options.
I am wondering if I should make individual families based on the front attachments or if there is a clever way of being able to select the back housing required and then via check boxes select the front attachment required.
I have attached the family I have made so far and the product data sheet.
Any help would be very much appreciated.
Chris L.
Solved by Alfredo_Medina. Go to Solution.
I suggest that the best way is to make a type catalog, since you are going to end up with many possible combinations of this fixture. Also, I would advise to handle those combinations with data, only, as opposed to making actual changes in the model; in other words, you should spend time entering information for each type, instead of modeling the variations of each type. This is because this is a small object, and changes to the actual model won't be too visible in a typical ceiling plan anyway, but the specific data of each fixture is important so that the final user can select and schedule the exact fixture with the exact properties.
If you are not familiar with type catalogs, please refer to the Help documents.
Thanks, that all makes sence.
Does it matter how many families I nest into the final family? Some of the parts that construct this product are used on other products we supply so just wondering if it is ok to put 4 familes into the final one.
Cheers.
It does matter, in terms of the size of the family. The more nested families, the heavier the final family is. Nesting is necessary for the content creator, though, otherwise, we would have to make every thing from scratch every time we need a component. In this case, however, you might be overmodeling this piece. It´s a small round lighting fixture. Which looks like a circle in the ceiling plans. All the stuff that is above the ceiling is not usually shown, so why should that be modeled in so much detail?
