Hi, I am not sure how to ask this, but our linked model is slightly cut off. When I pick the model a blue border shows up but it is not selectable for adjustment.
I would like to "stretch" it out a little. Is this do-able?
see the attachment
Rick
Solved by CoreyDaun. Go to Solution.
Hi Rick,
That blue outline is typically defined by the extents of the elements within that Model that are visible in the current View. If the model appears to be cut off, that it is likely that those elements are not visible in the current View. Check all relevant visibility settings such as Phasing, Design Options, Workset Visibility, etc., etc...
