I have posted this multiple times the last 2 years and still have yet to find an answer... so here we go again. I am having issues printing with Revit Architecture 2010, 2011, and 2012. We use a kip3000 and we are also using Autocad 2012. When we print from our computers to our kip3000 in Revit the prints show up just fine. but when we make a copy of those prints they come out chopping and with lines missing. But using the same printer if we print from Autocad it comes out looking fine and when we scan those prints they look just fine. Is there a way I can get Revit to prints just like Autocad. We have had employees in the field requesting that we no longer use Revit because of this issue because they cannot clearly read the prints. We really need to get this fixed or we will be at the point of no longer using Revit which is a shame.
So, when you print from Revit, the quality isn't good? But when you print from CAD, it's fine?
You've got a few options:
Good luck to you, and let us know how it turns out.
I have tried Raster vs Vector printing with the Kip and that did not seem to make a difference. But I will have to try these other options as I have not tried them yet! Thanks so much for your help! I will update when I have tried any of these other options and let you know if it has helped our issue.
Thanks again!
Kate
