Adding top landing to external stair
5 REPLIES 5
paul53_7
1241 Views, 5 Replies
I am having a problem adding a top landing to an external staircase.
Please see below image.
Every time i try and add the top landing i either get boundary error messages or railings surround top landing.
Any help would be appreciated.
5 REPLIES 5
ccollins
in reply to: paul53_7
You might need to just add a Floor. Landings are a bit problematic. Hopefully this will get better in RAC 2013.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
paul53_7
in reply to: ccollins
Thanks for you reply.
Is there any easy way of adding a floor as you suggested.
Thanks.
ccollins
You should probably already have a Floor for the upper Level? If so, you can just edit the sketch of the Floor
to create your landing.
Cliff B. Collins
St. Louis, MO
paul53_7
Thanks that has worked well.
Paul
ccollins
Glad it worked. Smiley Happy
Cliff B. Collins
St. Louis, MO
