Adding top landing to external stair
5 REPLIES 5
1244 Views, 5 Replies
I am having a problem adding a top landing to an external staircase.
Please see below image.
Every time i try and add the top landing i either get boundary error messages or railings surround top landing.
Any help would be appreciated.
5 REPLIES 5
You might need to just add a Floor. Landings are a bit problematic. Hopefully this will get better in RAC 2013.
Thanks for you reply.
Is there any easy way of adding a floor as you suggested.
Thanks.
You should probably already have a Floor for the upper Level? If so, you can just edit the sketch of the Floor
to create your landing.
Thanks that has worked well.
Paul
Glad it worked. Smiley Happy
