I am having a problem adding a top landing to an external staircase.
Please see below image.
Every time i try and add the top landing i either get boundary error messages or railings surround top landing.
Any help would be appreciated.
Solved by ccollins. Go to Solution.
You might need to just add a Floor. Landings are a bit problematic. Hopefully this will get better in RAC 2013.
You should probably already have a Floor for the upper Level? If so, you can just edit the sketch of the Floor
to create your landing.
