go to the properties of the printer in Control Panel, and then go to
advanced. Check on the options for Arch, etc that you need to see. Revit
uses windows plot drivers and settings, while Autocad/ADT use special
drivers of their own.
<365bare> wrote in message news:5532484@discussion.autodesk.com...
I no longer have the option to add different sheet sizes to Revit Building.
I only have ANSI sheet sizes available. Architectural is nolonger an option.
I can print using ADT using Architectural size sheets but not Revit. What am
I over looking? I've already installed a new driver. I've attacthed a screen
shot of my available options.
