I would like to add a column to the window schedule that shows the room number the window associates with. I was able to place a column in the schedule that is titled room number but it doesnt populate the fields in that column. I think there has to be a parameter setup for that and thats where I am stuck.
Solved by BalajiHTI. Go to Solution.
Is this still actual in version 2020 and above? I seem to have select available fields from Rooms, MEP-Rooms, but no From:Room and To:Room 😕
