Hi guys
When i start a new project sheet i can only get one level showing and i cant seem to add another level . where am i going wrong.
Solved by L.Maas. Go to Solution.
Easiest way is to go to one of your elevation views and add a level. When level is added you can add views for that new level.
Louis
Please mention Revit version, especially when uploading Revit files.
thanks for yor input but the level button in the datum section is not highlighted in any view wether its elevation, plan or 3D its like it is some how switched off. im running 2015 64 bit student edition.
