Adding a piece of Floor
3 REPLIES 3
USAArchitect
232 Views, 3 Replies
If you already have your main floor created in a Revit LT model and you later decide you'd loke to add a small addition to that same floor, not as an addition, but simply as a revised floor plan that expands the previous area, can you just draw another floor area and will that blend into the 1st main floor?  Or do you have to redraw the whole floor?  Or join the 2 pieces?  Thank you.
3 REPLIES 3
rosskirby
in reply to: USAArchitect
Select the floor, and in the Ribbon, in the contextual menu, choose edit sketch, then edit the floor boundary to be whatever you want.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
USAArchitect
in reply to: rosskirby
Of course.  I should have known.  Thank you Ross.  Still learning here; on my first project.  All my best to you and others extending friendship and help.
rosskirby
I'm glad I could help.  And don't worry, we're all still learning.
Ross Kirby
Principal
Dynamik Design
