Add Editable Text Box to Room Tag?
2 REPLIES 2
eacaron89
5525 Views, 2 Replies
I am trying to add a normal, regular, editable text box to a Room Tag. Our office is involved in a competition and we want to show the Room Name and Area (which I understand how to do and have done that) and also the required square footage that was given to us in the competition project description. Here is an example:
STUDENT SERVICES
1252 SF
REQ: 1160 SF < This is what I need to know how to do.
Once the Room Tag is placed, I want to manually be able to change that number as it pertains to each program. Is this at all possible?
Thank you!
2 REPLIES 2
SteveKStafford
in reply to: eacaron89
Create a Shared Parameter called Required Area
In the tag family create a new label and and browse/choose your new shared parameter
Load the tag into your project
In the project add a new Project Parameter based on the same Shared Parameter, assign it to the Rooms category
In the project you'll find your Required Area parameter listed in the properties of any room
You'll be able to enter the required area in the tag, room properties or in a room schedule if you include the Required Area field there too.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
eacaron89
in reply to: SteveKStafford
I DID IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you so much 😄
