Revit Architecture
Revit Architecture
New Member
0 Kudos
Post 1 of 2
add a leader to a symbol, no text
405 Views, 1 Replies
12-08-2004 12:48 PM
I have created a symbol with text attributes that I could modify. In this case the symbol is a "EWA" (exterior wall assembly) that I intend to add arrowhead leaders at four directions to indicate the extent of the wall type on a building elevation.
Is that a way to add a leader with arrowhead (with no text) to the symbol after I placed the symbol on the view? I do NOT want any extra text to associate with the leader. Just a plain, straight leader as graphical element that I could move, rotate and stretch. The result should look something like this:
<----------(symbol)---------------->
*Christopher Zoog
Post 2 of 2
Re: add a leader to a symbol, no text
12-08-2004 01:47 PM in reply to: cchong
There a few ways to get a leader with no text..... However from what you describe you need to look at your symbol family. If it was made as a generic annotation, your symbol should have the option for adding leaders, just add 4 leaders and position them as desired. Look at the keynote family as a good example. hth, Z "cchong" wrote in message news:7785035.1102538957101.JavaMail.jive@jiveforum1.autodesk.com... > I have created a symbol with text attributes that I could modify. In this case the symbol is a "EWA" (exterior wall assembly) that I intend to add arrowhead leaders at four directions to indicate the extent of the wall type on a building elevation. > > Is that a way to add a leader with arrowhead (with no text) to the symbol after I placed the symbol on the view? I do NOT want any extra text to associate with the leader. Just a plain, straight leader as graphical element that I could move, rotate and stretch. The result should look something like this: > > <----------(symbol)---------------->
Post to the Community
New Post
