We have a large project that has a design option set with two options, one for a shell space and the other as a fit-out. When I changed the fit-out to be the primary and then accepted that primary, all the rooms that were in the design option now do not recognize the walls as boundaries, making almost 500 rooms unbounded! Oddly about three rooms on each floor maintain their boundaries while the rest don't. There isn't anything different between those rooms and the rest. Is there something that could be causing this and how would this get fixed? Thanks.
