ACAD blocks and REVIT railing
3 REPLIES 3
304 Views, 3 Replies
I have used ACAD and a small application to make the drawing attached. My question is if it is possible to make this kind of railing components with REVIT. I have seen revit only twice and I find it a very powerful application but since I make designs for others, they want specific types for railing, doors, windows etc. I have seen from a help file the way we can make doors and windows but when I tried with railing it didn't work. Is it possible by adding mass somehow? I really need to learn REVIT so please help TIA, Dimitris
3 REPLIES 3
sbrown
Yes you can make those no problem. You make the peices just as you have done in acad as panels, the assemble the diff pieces with in the revit project. If you have revit there are tutorials on this in the help pull down, just search for railings, here is an example of 3 on a project I'm currently working on.
Additonally, if you need to share these with others, that's easy too. Just start a new project, and draw a railing. Load and apply your railing components then save the file. Send the RVT file to your clients. They open the RVT, cut-n-paste the railing into their project, and then they can apply that same railing style to any railing in their project. "sdbrown" wrote in message news:21105645.1093009469701.JavaMail.jive@jiveforum1.autodesk.com... > Yes you can make those no problem. You make the peices just as you have done in acad as panels, the assemble the diff pieces with in the revit project. If you have revit there are tutorials on this in the help pull down, just search for railings, here is an example of 3 on a project I'm currently working on.
Thank you both for your answer. What do you mean with panels? When I want to make a family, I open the template file and try to make the profile. The problem is that I cant make it work. The message I receive is 'Can't make type Family6' where family6 is the attached file. Please take a look at the file and tell me what's wrong. Thank you for your time and patience :-) Dimitris
