How can i get BuiltInParameter.LEVEL_IS_GROUND_PLANE parameter from Level?
why it's value always 0?
I want to get which Level is ground_plane.
and.
How can i get BuiltInParameter.LEVEL_IS_BUILDING_STORY parameter from Level in Revit 2011?
this parameter just support by Revit 2013 API?
Hi cfu18, welcome to the Revit Help Forum.
Please keep in mind that the best way to get fast answers and
solutions to your questions is to try and make then as understandable
as possible. Even if you describe your question a little more than
you think you need to, that is the best.
Someone will respond to your question soon.
You may get a quicker response in the Revit API discussion group:
http://forums.autodesk.com/t5/Autodesk-Revit-API/bd-p/160
I beleive that the "Story" parameter for levels is only in r2013. It is used for IFC export:
Joe
