About Links in Revit
2 REPLIES 2
470 Views, 2 Replies
When I link a revit file with another, i can't see the content of the linked file clearly (blurred line).
How can i make the drawing line of the linked file bolder to see the content of linked file clearlier.
Thanks very much.
2 REPLIES 2
ryan.duell
I included a few potential issues to keep in mind below:
1.  Temporarily set the View Properties > Discipline > Coordination.  Does the view appear more as expected [darker lines]?
2.  Change the link from <By Host View> to <By Linked View>.  In the View, type VG > Revit Links > Display Settings > click <By Host View> and change to <By Linked View>,  Specify a desired view if it does not choose the view you wish to see from the link.
3.  Linked Files use the line weights as set in the linked file.  Take a look at the blog post below top see if this behavior seems similar:
http://revitclinic.typepad.com/my_weblog/2010/01/linked-file-line-weights.html
Thank you,
Ryan Duell
in reply to: ryan.duell
Thanks vey much, Ryan
