About Date inserts in Revit (can you take off the time?)
1 REPLY 1
HonestSun
162 Views, 1 Reply
Hello all and thanks to any of you in advance that has the kindness to read through this post in desire to help out some random Revit user.
Ok, here's my problem. I got to build up a template paper cartridge for our office's future projects that we intend to do in Revit (we're currently learning/adapting the program and are making a switch, at least partially, from AutoCAD to Revit).
Overall, I didn't have much trouble except for some really specific little glitches that stains the quality of the cartridge (thus making the whole sheet look bad or at least, unprofessional).
The thing that I really couldn't find a way to get rid of is when I want to put a text insert that will show the last date the file was edited. Well, putting a date there wasn't a problem but along with that date, there is the time of the day in HH:MM:SS format. There is really no need for this info and just packs up useless numbers where the text should look clean and clear to read.
I thank you again for any information one of you can give me.
1 REPLY 1
in reply to: HonestSun
I suspect you are using a label that shows the date/time when sheet was
printed not the date the file was last saved. Suggest double checking.
wrote in message news:4840026@discussion.autodesk.com...
to read.
