3D Solid from ACAD
2 REPLIES 2
hamid
140 Views, 2 Replies
3D Solid from ACAD
Hi.. i have a 3D model that was made in AutoCAD and I want to make it as a Site Component in Revit. When I imported the file, I failed to see my 3D Model. Pls help....
2 REPLIES 2
in reply to: hamid
If your model in ACAD is 3D solids, you need to convert to 3D faces for Revit to read it. You can export to 3DS from AutoCAD, then import the 3DS back into AutoCAD to convert to faces. Then save, and import that into Revit, then you should see it. "hamid" wrote in message news:6925742.1093331193895.JavaMail.jive@jiveforum1.autodesk.com... > Hi.. i have a 3D model that was made in AutoCAD and I want to make it as a Site Component in Revit. When I imported the file, I failed to see my 3D Model. Pls help....
hamid
in reply to: hamid
thank you very much.
