I have a curved wall and I would like 3D model text or a image to insert onto the wall but it won't work, Does anyone no if this is possible? it wont work on a straight wall either.
Model Text cannot go along a curved wall, It can get hosted on straight or inclined faces of walls or any other elements.
To place the text along the face of a wall, select the Model text command, choose: set work plane ...click on the face of the wall...then the text will place correctly.
You can set this workplane on any other faces, including inclined faces but not curved faces.
Check this link for a workaround I have given
Hope it will help
