Hi.
I just tried to export our 3d model view to a 3d DWF file using the "export 3d dwf" option and noticed that Revit 9.1 won't create a dwf file at all. We tried on several computers with different files. It won't export anything.
We use linked revit files linked with shared coordinates.
It works fine when you unlink the files but then you are missing half of your model. It also worked okay with version 9.0, although the linked file in the exported dwf file was all gray (no materials).
Is there any solution known to fix that behavior?
Cheers,
Ingo
