I have a problem wit Revit 2014 from BDS Premium. I don't have 3D default view icon in Quick Access Toolbar and I can not add it. I tried to right click on QAT and customize it but unfortunately 3D view is not in the list and it can't be added by righ clicking on the icon.
Is there another way?
Thank you
Rudolf
Solved by lanl. Go to Solution.
Hi RudoIf,
You need to reset the Quick Access Toolbar to get the correct icons.
To reset the ribbon and Quick Access Toolbar:
Quit Revit 2014, then delete the UIState.dat file located in the Autodesk Revit 2014 folder as below:
%APPDATA%\Autodesk\Revit\Autodesk Revit 2014
THen launch Revit 2014, you will get the correct icons on Quick Access Toolbar.
The link below is for your reference (it is for 2012 version, only need to change the folder name):
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=16825244&linkID=21208795&siteID=123112
Thanks.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Oh, right, I know that procedure... I should do that before I asked :). Thank you, it works.
Rudolf
