360 and rendering
4 REPLIES 4
lbernacchi
559 Views, 4 Replies
360 and rendering
How do I find out how many times I can render different model? I know that there is a limit and I have looked everywhere but it is another thing that is buried deep.
Lisa
4 REPLIES 4
LisaDrago
in reply to: lbernacchi
It used to tell you how many 'cloud units' you had - now it does not... I have attached an image of mine...
You can use it freely for now. There is a limit but Autodesk says it is not able to control it so you can continue to render as you need to.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
scott_d_davis
in reply to: LisaDrago
yes, lisa is correct.  its currently unlimted.  so render as much as you would like in 360 rendering.
Scott D Davis
Sr AEC Technical Specialist
safsum
Hey does anyone know why revit 360 cloud rendering automatically changes my renders into solar studies? its really fustrating, im just after a normal render.
armandmeyer
in reply to: scott_d_davis
Good day. I do not know if this is the right place to post this, if not, i do apologize. I am currently studying and have in the past been making use of the cloud rendering service for students. Since updating to Revit 2013, i can’t sign in anymore. When I click on the sign in tab, a message appear saying "Requested service temporarily unavailable". I have been reading various Autodesk blogs, and none of the suggested solutions are working. I have changed my time and synced it with internet time; I have disabled my firewall and allowed access to the software. Nothing seems to work. I am really desperate to get this working asap. I have installed a trail version on another laptop of mine, and the service works on that laptop.. PLEASE HELP!
Thank you!
Armand
