2014 filled region model pattern
2 REPLIES 2
jbnarch25
2072 Views, 2 Replies
in 2012 I was able to have filled regions with a model pattern. In 14 the bubble to change the cut fill pattern is greyed out. I need to be able to rotate a pattern so i need a model one. Anyone else encountering this?
2 REPLIES 2
David_W_Koch
in reply to: jbnarch25
I was able to create a new Filled Region type and assign a Model pattern to it in Revit 2014.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
arunag
Model type is indeed disabled in cut patterns, you can create one drafting pattern same as model pattern by importing the .Pat file with type=drafting as the changed code. check this link for the detailed procedureof creating it.http://aectrainer.com/?p=171
Hope it helps.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
Rail Community
