Revit Architecture
Revit Architecture
jkunkel
Message 1 of 2 (2,876 Views)
2013 Worksharing Monitor Addin File - Where Is It?
2876 Views, 1 Replies
08-30-2012 08:24 AM
I have a user that is getting an error when he opens 2013 that says "Failed to initialize the add-in "Worksharing Monitor" because the assembly "[TARGETDIR]WorkSharingCommand.dll" does not exist".  So I figured I'd open the addin file and make sure it was pointed to the right path.
The Workshare Monitor files are installed properly to Program Files(x86), but i cannot find the addin file.  I can find the addin file for 2011 and 2012, but nowhere can I find it for 2013.  I searched on my PC as well, and no luck.
Where is this file living?
Product Support
Chris.Aquino
Message 2 of 2 (2,844 Views)
Re: 2013 Worksharing Monitor Addin File - Where Is It?
09-04-2012 01:18 PM in reply to: jkunkel
I would check the appropriate location below:
Windows XP:  C:\Documents and Settings\All Users\Application Data\Autodesk\Revit\Addins\2013\
Windows 7: C:\ProgramData\Autodesk\Revit\Addins\2013\
If it's not there, I would try repairing the installation of the Worksharing Monitor through the Control Panel. If the issue continues, I would copy a working version of the add-in file from a working machine to the one that is not.
Chris Aquino
Technical Support Specialist
Customer Service & Support
The Revit Clinic
@Revitclinic
