2013 suite work flows
8 REPLIES 8
Message 1 of 9
895 Views, 8 Replies
I have just installed Autodesk Building Design Suite Premium 2013. I am currently using a machine with 4GB RAM and windows 7 professional.
My Question is that when I hover over work flows, Revit hangs. Is this only RAM problem or something else and how do I sort this out.
8 REPLIES 8
Message 2 of 9
Lance.Coffey
If you are seeing Revit hang when just hovering over the workflows, the issue may be with the tooltip. To check if the tooltip is causing the hang, try turning off tooltips in the Revit options (in the User Interface section).
Also, when you are hovering over the Suite Workflows, do you have 3ds Max Design or Showcase open?
Lance Coffey
Technical Support Specialist
Tags (1)
Message 3 of 9
I upgraded my machine to 8GB RAM and NVIDIA Quadro 600 with 1GB RAM. I have also followed all instruction on workflow guide. The problem still persists.
Message 4 of 9
jdiaz
try reinstalling the program, and after that update it with "Revit Service Pack 1"
Message 5 of 9
aksrocks
Hi.
I'm facing this same issue.
Tried the tool tip solution as well as doing a clean install with and without service pack updates 1 and 2.
Has anyone got a solution to this as yet?
Thanks.
Message 6 of 9
Any Solution with your Suite workflows
Message 7 of 9
splaw
Even Service pack 2 doesn't solve the problem.I constant use export and I often move mouse over Suite workflow and revit hangs and I have to kill the job and loose everything. Why is Audtodesk not solving this problem ?? Very frustrationg. All the suggestions doesn't work.
This is a more Bug. I need Autodesk to solve Bugs and not generate new features as priority.
SP
Message 8 of 9
jdiaz
in reply to: splaw
Before applying service pack 1, you have to download Revit 2014 from Autodesk site, then install it as Trial. Run it a couple of time, then activate it. This was the only way I could make it work for me.
Try and let me know...
Thanks...
J. Diaz
Ross & Baruzzini
MIA North Terminal Development
Program Management Team
PDS Assistant Designer
Field Engineering
Please consider the environment before printing this email.
RESTRICTED - PROPRIETARY INFORMATION
The information contained in this electronic message and/or attachment(s) may contain confidential and/or proprietary information and is intended only for the person or entity to which it is addressed. If the recipient of this electronic message and/or attachment(s) is not the intended recipient, the recipient is hereby notified that any dissemination, distribution or copying of this electronic message and/or attachment(s) is prohibited. If you have received this electronic message and/or attachment(s) in error, please notify the sender by replying to this message and delete the electronic message and/or attachment(s).
Message 9 of 9
splaw
in reply to: jdiaz
The problem is due to a problem with Language chosen. When chooisng English it has to be set to US english. Any other english will have this problem.
Revit 2014 still have the same problem. It is not solved yet.
