HI guys,
First of all I love this new annotation but Tag Type parameter seems to be broken.
It always shows number of risers not treads (changing Tag Type does nothing)
Landing is never counted.
And there is no way of changing default values for text size which shows up as 1.1906mm.
Any help is greatly appreciated.
Milos
Seems to be working as expected.
I didn't think it was a problem. In any case I figured our my problem.
What was happening is that in instance options "end with riser" was unchecked therefore creating an extra tread, which leveled with the floor.
Since this is an instance setting now (changing riser or tread finish)
During creating stairs stage select "runs" subcategory and select proper settings. That will ensure that this specific stair types will follow modified settings.
