Revit Architecture
Revit Architecture
New Member
bcfoley
Message 1 of 6 (3,318 Views)
2013 Revit Update Error "Product could not be located on your computer"
3318 Views, 5 Replies
08-01-2012 09:04 AM
I downloaded the autodesk_revit_archotecture_2013-64x_update1.exe and installed this update on my computer, which worked.
When my co-worker tried to install the same update, he received an error message that reads:
"The update release could not be installed because the expected Autodesk product could not be located on your computer.  Make sure that you are using the correct update release for the product."
We both have Revit 2013 and both have 64 bit machines.  Any ideas on what is causing this error?
MikeMaloney
Message 2 of 6 (3,307 Views)
Re: 2013 Revit Update Error "Product could not be located on your computer&
08-01-2012 10:16 AM in reply to: bcfoley
It Sounds like you have the wrong update.........there is one for RAC 2013 "Standalone" verson like old, and the New REVIT   "common called OneBox".  verify which version you own and get the proper one accordingly.
HTH.
Mike
Mike Maloney
BIM Design Automation Coordinator
CH2M Hill
DarrenP
Message 3 of 6 (3,300 Views)
08-01-2012 12:21 PM in reply to: MikeMaloney
if your running revit from the buidling design suite you need to download this one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121968&linkID=16831210
New Member
ci_co
Message 4 of 6 (3,030 Views)
11-01-2012 08:07 AM in reply to: DarrenP
Yea this was wrecking my head. There are two different download sites –
Revit standalone:
Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121970&linkID=9273944
Update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679231&linkID=9273944
as part of the design suite
update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121968&linkID=16831210
update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
Depending on which you have installed one will work – the other you get ‘cannot install as expected Autodesk product cannot be located on your computer’ error message
Autodesk should make this known on both pages. Would avoid needless confusion and frustration.
Valued Contributor
tkendrick
Message 5 of 6 (2,903 Views)
11-26-2012 04:58 AM in reply to: ci_co
I had the same problem and even considered that there would be a different update for "One Box" versus stand-alones, but I didn't find the different download site.
Autodesk - Please make it MORE CLEAR which one is which and where to download them.
Use this link to tell Autodesk about features you need:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Active Member
squid44th
Message 6 of 6 (2,636 Views)
02-01-2013 08:16 AM in reply to: tkendrick
I have tried BOTH update 2 versions and neither one works for me.  We keep getting stalled at 85% and then it sits there doing nothing, wait, it says "Gathering required information..."  You say there are 2 separate update files one for just Revit 2013 and one for Revit 2013 BDS, but if you look, they are both the same size 83,079kb (I'm just saying)
