2013: Page Setup Workflow
1 REPLY 1
dbroad
174 Views, 1 Reply
Anyone know why you cannot pick the printer in:
Application menu->Print->Print Setup ?
Is this a bug?
It is counterintuitive to need to use the print button to pick the printer before using the print setup to choose the paper size.
Architect, Registered NC, VA, SC, & GA.
1 REPLY 1
as I have observed :
Print Setup (not Printer Setup ) looks to be  a submenu of Print...and when you choose: Application menu->Print->Print Setup you chose a shortcut to this menu, that refines the settings made in Print.
If you choose : Application menu >Print and you click directly on it not on the arow from the  right button the entirely menu opens (with Print Setup as a submenu).....seems to have a logic....
Constantin Stroescu
