2013- Const. Template: Ceiling Plans Bug
2 REPLIES 2
dbroad
446 Views, 2 Replies
Does anyone else have this problem with the Construction template?  I draw walls on level one and the switch to the ceiling plans->level 1 and no walls are shown.  After deleting the built-in ceiling views and recreating them, things work fine.
Why don't the default views work?
Architect, Registered NC, VA, SC, & GA.
2 REPLIES 2
VWD-MLM
in reply to: dbroad
You need to check the VG for the predefined view for the RCP..  Sounds like thecut plane and/or upper linits need to be adjusted for the wall ht you created.
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
dbroad
in reply to: dbroad
Thanks for the response.  I have just figured out that it was the phase filter.  The OOTB level 1 ceiling plan was set to a phase of A10 Substructure.  The floor plan Level 1 was set to Project Completion.  Have no idea what the rationale for such settings would be.
Rail Community
