i've been using 2012 for several months on a home licence from my work with no problems and suddenly this error has occured. i have tried the solutions as listed on this link below but none of the files are present?
can anybody help me further? i tried a repair but it didn't help
this is the log
Faulting application name: Revit.exe, version: 2012.0.2011.309, time stamp: 0x4d785e92
Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec4aa8e
Exception code: 0xc0000005
Fault offset: 0x0000000000050895
Faulting process id: 0x8b8
Faulting application start time: 0x01cd28a5bbbd6916
Faulting application path: C:\Program Files\Autodesk\Revit Architecture 2012\Program\Revit.exe
Faulting module path: C:\windows\SYSTEM32\ntdll.dll
Report Id: fbff371d-9498-11e1-997f-e81132da2048
in full
Log Name: Application
Source: Application Error
Date: 02/05/2012 22:21:45
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: samsung-PC
Description:
Faulting process id: 0x1320
Faulting application start time: 0x01cd28a98f0b2883
Report Id: d1661a68-949c-11e1-997f-e81132da2048
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-05-02T21:21:45.000000000Z" />
<EventRecordID>14613</EventRecordID>
<Channel>Application</Channel>
<Computer>samsung-PC</Computer>
<Security />
</System>
<EventData>
<Data>Revit.exe</Data>
<Data>2012.0.2011.309</Data>
<Data>4d785e92</Data>
<Data>ntdll.dll</Data>
<Data>6.1.7601.17725</Data>
<Data>4ec4aa8e</Data>
<Data>c0000005</Data>
<Data>0000000000050895</Data>
<Data>1320</Data>
<Data>01cd28a98f0b2883</Data>
<Data>C:\Program Files\Autodesk\Revit Architecture 2012\Program\Revit.exe</Data>
<Data>C:\windows\SYSTEM32\ntdll.dll</Data>
<Data>d1661a68-949c-11e1-997f-e81132da2048</Data>
</EventData>
</Event>
suggested solutions by Ryan doesn't cover the ntdll.dll error.
Do you have the installer/setup file available to do a fresh installation.
I tried a reinstall but it crashed near the end of installation now it says i have revit insalled but i can't unistall?
when i open revit i get the same problem.
i haven't how do you do this?
the problem has escalated, i used a program to uninstall as windows wouldn't let me, now revit has gone but when i try to install again it's says it's present.. very confusing
are you on Autodesk Subscription?
how did you bought this software, if through a local vendor, you should contact them.
If online, you can use subscription account.
